09-16-2009 03:52 PM
I enabled the NIweb services by checking "Enable Web Server" in Tools/Options/Web Server: Configuration. As I do not need this functionality I disabled the feature, but still my compiled applications create a "niwebserver.conf" file causing a runtime error. How can I disable the Web Services function?
Andreas L
09-16-2009 07:06 PM
Hi Andreas,
Exit LabVIEW. Rename your labview.ini file to something (to back it up). Ensure that there is no labview.ini file beside labview.exe. Now launch LabVIEW. If you are still getting an error, the error is not due to web services. We'll require more information to solve the problem.
If the problem persist, please try repairing the LabVIEW installation.
09-17-2009 02:46 AM
I deleted the LabView.ini file and started LabView again. I created a new build of my application. It still creates the niwebserver.conf file, which causes a runtime error.
Andreas L
09-17-2009 04:01 AM
10-08-2009 08:54 PM
hello,
i also have that file when i untick the web services. What is NI web services main function actually?
zull
NI LabVIEW 8.6
10-11-2022 09:08 AM - edited 10-11-2022 09:09 AM
Thanks NitinD! This worked for me, had the same issue. Just to add: it looks like the niwebserver.conf file gets built with an app if there is the same .conf file present in the LabVIEW program folder
