08-16-2012 09:04 AM
I want to move the file from the FTP saver to local PC , but am getting the error 15550 with the source FTP Transaction : 550 the parameter is incorrect, i have attached the VI and the word documents containing the errors that i get as i execute the VI
08-16-2012 09:38 AM
Leaving LabVIEW out of the equation can you FTP with an FTP client without errors?
08-16-2012 09:39 AM
Hi Nassor,
Your local path and remote path should both contain filenames, not directory names, as you are currently not specifying a file to send.
For example, to send a file called test.dat in the /data directory, you should set the local path to "/data/test.dat".
The same should be the case for the remote path.
Hope this helps.
08-17-2012 07:02 AM
yes it was working fine with FTP saver and FTP client, thank you for the help let me work out on the advice,
08-17-2012 07:42 AM - edited 08-17-2012 07:48 AM
Hi LaThoS,
I have done it now am getting the error 7, please see the attached word doc with the VI front panel,
Regards
nassor
08-20-2012 09:35 AM
Hi LaThoS,
Error 7 typically translates to File Not Found. Can you double check that the file path is correct using the command prompt or file explorer? Also double check that the path is formatted correctly. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux.
08-20-2012 10:55 AM
Hi Nassor,
I think the problem is now coming from the fact you have used an absolute file path for the remote host. You should only use a relative path ("\ftpdata\test.xlsx"), as this gets concatenated with the host IP to form, in your case, "196.44.162.161\ftpdata\test.xlsx".
Hope this helps.
08-21-2012 08:48 AM
Hi Kaitlin N,
I have checked with the path for both FTP saver and FTP client and they are all ok i did this using the command prompt also the path separators were correctly written but i still get error 7.
Thank you for the contribution.
Regards
Nassor
08-21-2012 09:08 AM
Hi Laurence Stant,
i have re written the remote path as you suggested, remote path i putten like this ''41.86.165.150\ftpdata\test.xlsx'' and the local path was ''C:\seismicdata\test.xlsx'' but still i get Error 7. I have attached the front panel of my VI with all the filled information also the Error displayed.
Thank you for the help.
Kind Regards
nassor
08-21-2012 09:14 AM
Hi Nassor,
It seems I may have been confusing. You should put the IP address as the host (as you are now), but only "\ftpdata\test.xlsx" as the remote path.
