how to set up vi to read computer time
I'm trying to record data of a graph of temperature versus time. I have set up my VI just like in the attached photo. and used waveform chart but that only gave me a certain period of time so I switched to waveform graph, however I can't get the x-axis (which is time) to read the same time of the computer and date for a period of about an hour to an hour and a half. Any suggestions on how to fix this problem would be appreciated
Message 1 of 12
(5,250 Views)
Please attach an actual VI.  When youi use Express VI's like the DAQ Assistant, and the Dynamic Datatype wire, so much stuff is hidden behind the scenes, a screenshot of what otherwise looks like pretty basic code tells us nothing.
Message 2 of 12
(5,219 Views)
Also, why do you have a To Dynamic Data Type Express VI in there?  You are going from a blue DDT wire that is then being coerced (red dot) to an array of waveforms that is then being turned back into a DDT wire with that Express VI.  We can't see what actual conversion is going on in there, but that may be the reason you are losing timing information.
Message 3 of 12
(5,200 Views)
change your x-axis to display format to absolute time and set your x-axis offset and multiplier.  Offset is time started collecting data and multiplier is the sample rate in seconds. So for example 0.1 sec is every 100 milliseconds.
Message 4 of 12
(5,190 Views)
I'm not sure what do you mean by actual VI, I have attached a picture of the whole front panel of the VI file. As for the wiring, I don't have lots of knowledge on how to build the block diagram so that's what I came up with.
Message 5 of 12
(5,188 Views)
I have already did that and set the offset to 0 and multiplier to 1 but still the same issue
Message 6 of 12
(5,187 Views)
If your sample rate is 1 second that is the correct multiplier. On the timing palette use get system time and convert to a dbl. Use the time stamp from the sampling device if it is correct time. Or create a time stamp at start of sampling. Offset_mult.png
Message 7 of 12
(5,181 Views)
Ummm....  The file that LabVIEW actually saves with the extension .vi  ..........    Smiley Frustrated
Message 8 of 12
(5,170 Views)
Bill
CLD
(Mid-Level minion.)
Message 9 of 12
(5,162 Views)
Is this the file you're looking for?
Message 10 of 12
(5,153 Views)
