> I am trying to set a knob or a dial to be set to values such as .2 ,
> 5, 1, 2, 5, 10, 20 etc... on the same knob, but I do not want it ti
> interpolate to the values in between, I just want those to be the only
> choices available.
The best way of doing this is probably to make the knob be a text knob.
Enter the numeric values in as strings. They will be evenly spaced,
but that is pretty close to what you want. Next, you will need to do a
table lookup on the diagram. Build a constant array with values of .2,
..5, 1, 2 ... so that you can take the ring and index the array with it.
This will give the front panel appearance as well as the diagram value
that you want.
Greg McKaskle
