If you are using LV 8, there is a built in function to perform a "make current value default" at end of you VI.
If LV 7 and older there are some tricks, that have been explained and re-explained on the forum, so do a search with "make current value default" and you'll find all you need.
Hope this helps.
Epictetus
Antoine Chalons
