how to set combobox of a cell in Excel
generally ,it is quite easy to write or read data into or from excel files by labview, but today I need to set the dropdown choices of a cell by labview and it seems it is a little difficult .
what I need is as below:
for example,I want to set the 3 dropdowm choices by labview to a cell,what shall I do?
thank you!
Message 1 of 8
(4,681 Views)
hi,
you find below solution for your topic :
Best Regards .
Kudos are welcome .
Message 2 of 8
(4,652 Views)
@Emna20 I think the OP wants to use LabVIEW to create a combobox in Excel, not to populate a combobox on a LabVIEW FP.
@alii001 In Excel, do you mean a form control Developer - Insert - Combo Box (Form Control), an ActiveX control Developer - Insert - Combo Box (ActiveX Control) or the drop-down list available from the right-click menu of an individual cell, sometimes called a data validation list?
Message 3 of 8
(4,647 Views)
This might be useful if you're trying to use a data validation list.  A description of the parameters for the Validation.Add method can be found on the Microsoft web site.
Message 4 of 8
(4,642 Views)
Accepted by alii001
hi ,
add (true to wait until printing completed ) and (true to Save changes ) .
Message 5 of 8
(4,631 Views)
Thank you! thank you ! I have tried for several days, but got no answer, you are really kindheart and forums.ni is really a great place.
Message 6 of 8
(4,625 Views)
I have tried for several days of it, but got no answer.
thank you!
@PsyenceFact  已写:
Message 7 of 8
(4,621 Views)
You're very welcome! (As are Kudos Smiley Wink)
Andy
Message 8 of 8
(4,618 Views)
