how to separate certain numbers from the whole output?
The following was got from the standard output window of the 'calling system exec' vi. My question is how to separate the 'actual read value' numbers (in bold) from the whole output and output them separately.
37- Result=OK, line=0x5D,RW,0x21,, #Read VOUT_COMMAND value
   Actual Read Value:0x3000
38- Result=OK, line=0x5D,WW,0x21,0x3000, #Write VOUT_COMMAND to '1.5 V'
39- Result=OK, line=0x5D,WB,0x00,0x01,# write PAGE to 1
40- Result=OK, line=0x5D,RW,0x8B,, #Read READ_VOUT value
   Actual Read Value:0x3002
41- Result=OK, line=0x5D,RW,0x8C,, #Read READ_IOUT value
   Actual Read Value:0xBBB4
42- Result=OK, line=0x5D,RW,0x96,, #Read READ_POUT value
   Actual Read Value:0xC2C7
Thank you very much.
Message 1 of 8
(4,391 Views)
Search the string for "Value:" and take the number after it up to the linefeed character.
Message 2 of 8
(4,373 Views)
Here is a way to do it with regex. This assumes all values will be hex in the 0x... format.
Disclaimer: I am not a regex pro and there could be an easier way to do this, possibly without the while loop.
Message 3 of 8
(4,369 Views)
Accepted by topic author ZCY4444
Right on! You're at least 80% of the way there with this solution, but as you mention the regex could be improved a bit to be more robust. But the structure of the code (including the While Loop, autoindexing w/ conditional concat) is spot-on. (Only code structure i would change is not wiring the "multiline (F)?" input on the Match node, but rather, specifying this in the regex itself if necessary -- most of that is preference, not correctness -- and in this case, we don't need multiline since we're shifting the start index)
Have a go with this regex: (?<=Actual Read Value:)0x[0-9A-Fa-f]{4}(?=(?:\s|\z))
Read it like:
  1. (?<=Actual Read Value:) -- Lookbehind as a zero width assertion, ensuring it's before the match but not part of the match
  2. 0x -- text literal match
  3. [0-9A-Fa-f] -- Look for any one hex character...
  4. {4} - ... and repeat that character exactly four times
  5. (?=(?:\s|\z)) -- and Lookahead, to ensure that hex value is following by either exactly one whitespace character OR the End Of String anchor, without capturing that subgroup as a match
Message 4 of 8
(4,335 Views)
Oh fiddlesticks. This is what happens when forum software doesn't correctly construct regexes for smiley replacements 😞
Copy this one:
Message 5 of 8
(4,334 Views)
Thanks a lot for the help! It works now
Message 6 of 8
(4,320 Views)
right on! for(imstuck) did the heavy lifting here 🙂
Message 7 of 8
(4,313 Views)
Thank you very much. Smiley Happy
Message 8 of 8
(4,309 Views)
