how to save values and information in a spreadsheet?
Here is a snippet of a vi I made that I use after I have taken a series of measurements.
This takes on line of data, in the form of a 1D array, timestamps it, converts it to a spreadsheet string and writes it to a file.
This creates a TAB delimited file that can be opened directly by Excel if you give the file a .xls extention.
If you want colum headers you will have to put them on the file first
=== Engineer Ambiguously ===
Message 11 of 15
(878 Views)
Hey mate,
I'm using LabVIEW 8.5 so I had to make your code here... in the file path I have to put only the destination right?
I'm putting like "c:\"  and it's appearing that:
 Possible reason(s):
LabVIEW:  Unexpected file type.
c:\
Thanks for the help
Message 12 of 15
(859 Views)
EduU wrote:
Hey mate,
 Possible reason(s):
c:\
Thanks for the help
You have to put the entire path and file name.
C:\directory name\datafile name.xls
Message 13 of 15
(858 Views)
Hey,
I am new at this labview stuff. I have been looking at various examples and I got this vi and modified to my own need.
It would retrieve the data generated and transfere it to excel, but I have a tiny problem with this vi. I would like the program to place the each values that were retrive into appropriate cells (like a delimiter). So far its retrieving the data and putting all of them into cell A1. can some one help me please??
Message 14 of 15
(613 Views)
You really should have started a new thread.
The reason it puts it all into A1 because that is the way it is programmed.  It is hardcoded for cell A1.
Message 15 of 15
(601 Views)
