11-25-2010 04:50 AM
I think we have come to a stop here. Unless you post your code we will not be able to offer more help 😉
12-01-2010 02:40 AM
this es code but through ds code i m able to paly the audio coming but it es not saving hte data as .wav file so wt es the problem in this code, n i hve to ask one more thing can i save the audio in mp3 fomat in labview?
zohaib
12-01-2010 10:56 AM
12-03-2010 07:04 AM
It is no point in posting a diffuse picture. Please always post code with your current settings made default;)
12-09-2010 02:55 AM
i m recording audio data from one channel using daq card (6025e) with date and time stamping can i record audio data from all the 16channels simultaneously in separate files of each channel??
zohaib
12-09-2010 02:57 AM
this my vi
12-10-2010 01:29 AM
hellooo coq rouge sorry for the late reply plz reply me??
12-10-2010 08:25 AM
Can you tell me more about your project. Like what kind of signals do you want sample, what kind of frequency range do you need. Do you want to play the sound with a sound card/ standard media player. Your daq card has a max samplerate of 200 KHz. So 16 sound channels hmmm. I am not sure how well this will work.
12-10-2010 09:24 PM
Thanx coq rouge for your actually i want to record voice conversation from multiple channel like telephone ,walkie talkie and etc therefore all of them will be audio signal ,there frequency range will be around 10k to 22k i m nt sure abt it, i dont want to play the audio in real time bt i want the play the recorded data when it is required, when i select multiple channel it shows nothing in output? and how i split the audio data of different channel of daq card? , can u explain with some vi or update my vi
12-14-2010 08:18 AM
All you need to do is select all the channels that you want to read in on your front panel, and then on the DAQmx read, select multiple channels/multiple samples and that should get you the channels that you are looking for.
