how to run simulations of MIMO models having direct feedthrough, using the control and simulation loop?
say i have the MIMO model of a system in transfer function as
4s + 4       0
10s+1
                                =   G(s)
0             3s + 3
               10s+1
this model has direct feedthrough. how do i run simulations of to say, a 2 step inputs?
I don't get any output signals. please, see attached VI file.
thank you.
(2,180 Views)
Hi tomcruize79
Thanks for using the forums!  Sorry for the delay in getting back to you - how have you been getting on with this?
One thing to note is that you can use the Signal Generator VI to generate a function as an input.  Try this with your model and let me know how you get on.
Peter D
(2,135 Views)
problem solved... i got directly intouch wth a support engineer. solution was a patch to correct a glitch in LabVIEW 2010 Control Design toolkit.
thanks!
(2,133 Views)
