01-13-2006 01:14 PM
01-13-2006 01:33 PM
01-16-2006 04:46 AM
01-16-2006 11:58 AM - edited 01-16-2006 11:58 AM
You just need to use the appropriate front-panel property node to either keep it hidden and/or close it when you are finished.
This hides it, has a space for whatever work you need done and then closes it.
Message Edited by Warren Massey on 01-16-2006 10:02 AM
01-16-2006 12:03 PM
01-16-2006 02:08 PM - edited 01-16-2006 02:08 PM
@Dennis Knutson wrote:
Since the example I pointed out uses that property, how is your solution different?
If you are talking to me Dennis (and I'm not 100% sure you are), your "CommandLine" example didn't answer Pomo's question/concern/statement that said "Let me ask you the last thing: I created the executable file with the "Application Builder" of LabView. When I double click on the exe it runs properly but at the end it does not close the front panel. I don't [particularly want] to see the front panel during the execution of the exe, but mainly I would like that [it] is closed at the end of the execution."
The code picture I posted shows how to hide and close a front panel window.
Or was there another example that you pointed out that I missed?
Message Edited by Warren Massey on 01-16-2006 12:09 PM
01-16-2006 02:40 PM
01-17-2006 01:51 AM
02-08-2009 02:07 AM
03-24-2009 12:39 PM
I need help with this issues of running .exe file by labview.
should i create a new thread/post or continue with this thread?
thanks in advance
