Hello AD,
If understand your question correctly, you would like to command a VI to start execution on a remote computer. If these computers are connected using a network, I would suggest using the VI Server to command the remote VIs. This will allow you to not only execute the VIs, but also perform more advanced operations such as setting the front panel control values remotely
The
Tutorial linked here is a good place to start with using VI server. It also includes an example of creating a VI and running it remotely.
Have a great day!
Scott Y
NI
