how to rotate an imaq image
I'm trying to rotate an imaq image. I have seen I need to use "image manipulation.llb" to do so. where can I find it?
thanks,
Gilad.
(5,540 Views)
This may be similar to what you mentioned but have you tried using this VI:
http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_rotate/
--Ryan S.
(5,530 Views)
do you have the vision development module installed?
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(5,522 Views)
No. I don't have this module installed. is there any other way to do so without using this module?
(5,454 Views)
To use the IMAQ Rotate VI you would need to have the Vision Development Module. There are other ways I can think of, but you would need the Vision Development Model to try them as well.
Cameron T
(5,441 Views)
If you can convert the image to a PNG file, you can load it and rotate it using the standard LV picture control. You can see an example here - http://forums.ni.com/t5/BreakPoint/LV-Picture-Control/m-p/230351#M748
___________________
Try to take over the world!
(5,436 Views)
