how to receive data via tcp/ip data socket
Hi Bosski,
did you simply try to connect to your modem using the tcpip functions? From your image you know the ip and the port. Use the TCP Open Connection function. If this work, then you can send commands to it and read data from it. Check your modem description for the protocol.
Mike
Message 11 of 11
(525 Views)
