how to read manualy typed excel into labview
I need to read manually typed  excel file in labview 7.1,
as I cannot change labview version to 8,
Please let me know if I can read the normal excel sheet which is typed by operator,
How to read in labview 7.1?
Thanx
Swati.
Message 1 of 13
(4,291 Views)
Hi Swati,
you can use the ActiveX functions from Excel. And as far as i know there is a library to do it.
Mike
Message 2 of 13
(4,285 Views)
Hi Swati,
Read the file as usual using the Open File --> Read File --> Close File method & convert the String data into 2D String Array using the Spreadsheet String to Array function from the String palette, by giving the Delimiter as ",".
This ll do the job for you.
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 13
(4,283 Views)
Does your filehas the extension .csv or something else?
Message 4 of 13
(4,282 Views)
Hi Partha,
I tried converting string into array
what shuld be the format?
%s?
i gave delimiter as comma,
didnt read anything,
Thanx.
Swati.
Message 5 of 13
(4,269 Views)
No man,
no csv file just one simple excel file where i typed something like any number or string and i am trying to read it in Labview,
and i m not able to do it,
Actually,I have to read a master spreadsheet file at clinet location for reading some parameters in labview,
But this seems to be hard than i ever thought,
Please do help me,
Thanx
Swati.
Message 6 of 13
(4,266 Views)
Hi Swati,
see this link: http://zone.ni.com/devzone/cda/epd/p/id/3409. I think this should help you.
Mike
Message Edited by MikeS81 on 03-27-2008 11:37 AM
Message 7 of 13
(4,263 Views)
Hi
  Just Save the Excel sheet as csv text files and read the using the read spreadsheet file.vi, its simple and easy
Message 8 of 13
(4,260 Views)
See the attached code image.
For me, it read both noramal Excel file & CSV file also.
Message 9 of 13
(4,253 Views)
Thanx,
It worked,
Only i will have to save that master file with csv format but wil try
thanx
Swati.
Message 10 of 13
(4,246 Views)
