how to read a cell's value from a line
hello;
i need the name of a fonction which is able to read a cell's value from a line. the line contains many values.
if you can post it for me ,i'll be great
Message 1 of 27
(4,074 Views)
The question is very vague, please be specific. Also post any code you have already done.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 27
(4,067 Views)
Index Array 🙂
More details definitely needed.
Message 3 of 27
(4,065 Views)
i have a text file which contains meteo's values: speed of wind , humidity ,temparature ...
i would like to know a function which separate values of each line . afterward show it in a waveform.
Message 4 of 27
(4,050 Views)
Read from Spreadsheet File and an Index Array (already mentioned).
Message 5 of 27
(4,041 Views)
Spreadsheet String to Array.  That will give you a 2 dimensionsl array containing the values.  Then just index the array.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 6 of 27
(4,040 Views)
Oh, I missed that.  It's a file not a string.  Yes, Read From Spreadsheet File.
Kelly Bersch
Message 7 of 27
(4,037 Views)
thank you
but. post an example please. just for one column
Message 8 of 27
(4,024 Views)
Wire the 2D output of the read to the Index Array. Wire a numeric to the column input of the Index Array. Done.
This is pretty basic. Have you taken any of the LabVIEW classes or the free tutorials?
Message 9 of 27
(4,017 Views)
@pousse wrote:
thank you
This forum is not here to teach LabVIEW basics.  I'll gladly help someone who is trying but I won't do your work for you.  This is basic stuff.  Work through the tutorials then try to solve this.  If you run into problems after that come ask for help.
Kelly Bersch
Message 10 of 27
(4,012 Views)
