how to put two Amplitude levels on same waveform graph
hi,
i have am aquiring two signals from a DAQ device and i want to show them on a single graph or chart, but the problem is that the voltage signal is of 30 volts and the current signal is in milli Amps, so how set get two Amplitudes on one graph because with only one Amplitude it is not possible to see the signal in milliAmps which is very small,
any idea how could i set seperate amplitude for both signals in one waveform graph or chart,?
thanks
(3,380 Views)
Hi malik123,
you can create a new axis. Right click on the existing y axis and select copy. After that you can assign the second signal to this axis.
Mike
(3,378 Views)
MikeS81 wrote:
... After that you can assign the second signal to this axis.
Mike
....Which can be done programatically or by right-clicking a channel in the plot legend.
Ben
(3,373 Views)
THanks ben and mike
(3,328 Views)
