how to put strin in x -axes
Dear Sir,
How take an X,Y plot where X- axes having a string value like (date , time, and days).
Here I have attached my program and observation file.
(3,384 Views)
Hi Julian,
when you want to have dates you could switch the formatting of the x scale to show dates. Use the advanced formatting options...
(3,381 Views)
Dear Sir,
Thanks for your suggestion, I don't want to see dates whatever is given in system , but i have a data in string formats it may have dated or name also, i that case Graphs takes only integer value. So please suggest me , program to insert string in X-axes.
Thanks & Regards,
Prince
(3,373 Views)
Hi Julian,
the scales only display numbers (either formatted as integer, floats or time/date). Strings are not supported.
To display strings you can hide the scale and put your own string indicator on top of the graph...
This has been asked a lot of time before, just search the forum!
(3,371 Views)
As Gerd already mentioned you can use the formatting of the X-Axis but if that does not meet your needs...
Take a look at the code I posted in this thread.
It uses a Picture Control that over-laps the X-Axis to render arbitrary text under a bar graph.
Ben
(3,354 Views)
