how to present each case in a case structure a certain percentage of the iterations
@jcarmody wrote:
Maybe the probability of a "1" is valid for each element, but I don't think this is what the OP wanted.  This example should have five Trues, no?  I couldn't get it to fill it with 15 Trues, but 14 happened pretty quickly.
What point are you trying to make? If you have a 0.25 probability for each element, a sum above 14 is very unlikely (but with a probability that can be calculated exactly).
It really depends what the OP wanted. If you know that there are exactly 5 trues every time, you can often predict the outcome early. For example if the first 15 elements are false, you can predict the outcome of the next five with 100% certainty. Same if all five TRUEs show up early. Only the Bernoulli solution gives you unpredictability up to the last pick.
Message 11 of 14
(641 Views)
My point was that Bernoulli Noise.vi doesn't do what was asked.  If I change my "ones probability" constant to 0.1, I get three Trues more often than I get two.  The OP wrote "I want to present the test stimulus on 90% of the trials and the catch stimulus on 10%".  OP didn't say that he wanted a 90% probability of a test stimulus being presented at each trial.
Jim
Message 12 of 14
(632 Views)
As I said, this makes the test flawed if the subject is good at "card counting". Just trying to help. 🙂
Message 13 of 14
(625 Views)
@altenbach wrote:
[...] Just trying to help. 🙂
You did, thank you, but I missed your point the first time.  I understand now...
Jim
Message 14 of 14
(607 Views)
