how to play avi file full screen with vision aquisition
I am playing an avi file with the Vision aquisition software and I would like to see the movie full screen (without the labview bar at the top and the windows bar at the bottom).
Does anybody know if it is possible?
(2,601 Views)
it is possible.
You shall set you main UI VI's properties (hit ctrl + i) and select the "Windows Appearence" category then go to custom parameters and review all the options, one is called something like "has title bar".
You can also set those properties programmatically using property nodes VI >> Front Panel >> Title bar Visible ; and you have many more options, have fun!
ps : I'm home and don't have LabVIEW at hand.. I would have made a screen shot otherwise, sorry.
Hope this helps anyway.
Epictetus
Antoine Chalons
(2,593 Views)
