10-30-2012 02:35 AM - edited 10-30-2012 02:54 AM
hello,
i want to know about reset function.
in my system i am dealing with different instrument like power supply ,GPS,GSM...
in my system i have 2 section in 1st section i have set only ON and OFF operation of my devices and in second section i have to deal with Current and Voltages and GSM's task,for that i have put one start switch (from boolian)after giving start 2nd section will start to perform operation until the end and LED of regarding section will be ON,but when i press start switch again then my 2nd section shoud be reset and from begining it shuld be start to perform operation.
here in attachment i attach my front pannel in that you can see that on start button i have used after pressing it my system shoud be reset that i cant do it.
please let me know what kind of logic i have to use for reset the function.???
thanks in advance.
Solved! Go to Solution.
10-30-2012 02:50 AM
I would be much easier to understand what you are doing if you could show us some code.
Instead of ordered consecutive "sections", it would probably be much better to implement a state machine, including idle and transition states.
10-30-2012 02:58 AM - edited 10-30-2012 03:00 AM
i attach here my all vi.and in this there is start button after pressing start my all funcion shoud be reset.
its ok or i need to explain my problme in more detail.
10-30-2012 03:14 AM - edited 10-30-2012 03:18 AM
You only attached the project file, it does not contain any VIs. Just zip up the VIs or create a source distribution, for example.
(according to the diagram image you have now attached to the original post, your diagram is gigantic (look at the vertical scrollbar!).)
10-30-2012 03:30 AM
check this out.
10-31-2012 04:32 PM
hello,
i have use same logic which i attach here,but as my operation of vi is so long i cant stop my runing vi at a time when i press the butten (means i have to wait until all the proccess within loop shoud be finish) which is shown in front pannel in attachment (stop application).
thats why i m thinking to use stop function(Programming << application << stop) which is stop all the proccess at a time but i didnt find out proper logic for that.
please suggest me some logic so by using that i can generate one stop button on my front pannel and any user want to stop running vi at any time , they can do it by simply pressing that button.
10-31-2012 06:53 PM
i dont understand your english, logic or reasoning....but i would make your stop button a switch and a local variable wired to the second loop stop if true and finish your vi with a false reset to your local stop variable. please provide a visual aid to explain your logic?
11-01-2012 02:14 AM
hii,
in my vi i want to set some function which customer can easily understand,
i want to make one run button ,one stop button
i got success to creat run button by following attached vi in my previous post,now i want to make one stop button by pressing that user can stop running vi at any time.
but the problem is in previous attachment is that i can't stop my vi at any time i have to wait until all operation of while loop shuld be performed.
11-01-2012 03:06 AM
Ok i got success to halt at any time ....
thank you very much for every one who gave their time ....
11-01-2012 03:10 AM
can it possible to create pause button in vi,which give simmiler function which is on the top bar menu.
