how to overcome the "The wire is a member of a cycle" without initilisation?
i want feed back the value from fromula node where i am not using any loop.i i try to connect the output as an input through select control,its not able to connect its telling that "wire is a member of a cycle" how to overcome this .........
(2,918 Views)
Shift registers and feedback nodes only make sense in a loop. Without a loop, you only have exactly one iteration. Period. 🙂
Are you running your pogram with the "continuous run" button?
Please tell us what you want to do and attach your code so we can offer advice.
(2,914 Views)
