how to output the digital clock and synchronization signal from the NI USB-6211
I need to connect the NI USB-6211 to control a digital to analog convertor chip (AD5541). However, this chip requires three input signals :1) Clock input, 2) Logic input or a synchronization signal  and 3) Signal Serial Data input (CS, SCLK, DIN).
how to output the digital clock and the synchronization signal from the NI USB-6211?
(2,956 Views)
Hi SaberSaber,
You should be able to use the counters to generate a pulse train that could be used for clock and synch purposes.
Hope this helps.  Let us know if you have more questions.
Dave C.
(2,916 Views)
