how to open anritsu ms9710b device driver?
Hello
I have a question about opening anritsu ms9710B instrument driver. The question can be very trivial for you but I couldn't find a solution and post this question here. The question is how can I open a library written with labview 5.0 in a computer using labview 8.5? It is giving me an error saying that "error code 10, labview version is too old(5.0) to convert to current labview version(8.5)". I installed the library  from the link:http://www.eu.anritsu.com/downloads/default.php?f_product=&f_search=LabView&show=search. If you want to open the library the file is also attached
Caglar.
Message 1 of 8
(1,788 Views)
Highlighted
http://forums.ni.com/ni/board/message?board.id=170&message.id=473173&query.id=1163648#M473173
Please post in this up-conversion thread. Somebody will convert the 5.0 files to 8.5. Did you searched for the driver in NI website? Maybe there will be a newer version of drivers available.
Message 2 of 8
(1,777 Views)
Highlighted
Thank you very much for your fast response. I need this driver terribly. I didn't see the upconversion thread so posted in here now I will go and post my request there. I found this driver from anritsu website but ni website directed me to there. I think they only have this version.
Message 3 of 8
(1,770 Views)
Highlighted
There are 81 files. Can you tell me which is the main vi?
Message 4 of 8
(1,767 Views)
Highlighted
Accepted by topic author ankarali
Message 5 of 8
(1,761 Views)
Highlighted
hello
this is a library for the instrument driver of anritsu MS9710B. They didn't save it as a .llb file but just zipped  all of the vi's in the library. For my application I will not use all of the vi's in the library but I don't know which vi is using which vi in the library since I can't open and need conversion for all of the library. Isn't it possible to compile all directory at once or should it be done one by one? Is it possible to convert the directory in a .llb file  without opening vi's in the library and then upconvert? This is the original .exe file i installed from the anritsu website at the link:
Thank you for your kind help
Message 6 of 8
(1,756 Views)
Highlighted
hi,
http://forums.ni.com/ni/board/message?board.id=4170&message.id=32481&query.id=1177575#M32481
driver here
Greg S.
CNRS
LV 7.1 8.2 8.6 2009 2011 2012 2013 2014
LPMC - CNRS
N'oubliez pas de complimenter cela fait toujours plaisir.
Message 7 of 8
(1,746 Views)
Highlighted
That's great. Thank you very much for your help. I think I can open it right now.
Message 8 of 8
(1,739 Views)
