how to manage web page content via labview
My pproblem is to get cyclic information from a web page containing an
applet.
Using a container I cannot manage any text and object in the page. Isn't it?
Ciao
(4,377 Views)
If I understand you correctly, you are hosting a webpage in a front panel ActiveX container, and you want to obtain certain information from the webpage.
This is possible using ActiveX calls. To get access to the HTML document in the container itself, along with all of its text and applets, etc, you need to reference the Document child item from a property node. This item is variant, so you need to use Variant to Data with a ActiveX refnum constant set to MSHTML.IHTMLDocument2 wired to the type. At that point you can access information about the HTML page itself, such as the body's text and so forth.
I'm attaching a simple example that should help you get started. It's written in LabVIEW 7.1. Good luck!
Jarrod S.
(4,346 Views)
"Jarrod S." <x@no.email> wrote in message
news:1140028999545-325331@exchange.ni.com...
webpage.
forth.
> HTML Document Info.vi:
> http://forums.ni.com/attachments/ni/170/167660/1/HTML Document Info.vi
Thanks a lot!!!,
maybe you didn't grab 100% of my needs because of my student english.
But for sure you are close to 90%.
Your solution is perfect but it takes time (and band) to download the entire
page. Is it possible to retrieve the HTML code?
So I try to ask you
(4,333 Views)
Hi again!
Yes, you can directly access the html source code. This is extremely easy in LabVIEW using the DataSocket VIs. DataSocket is a general high-level network communication platform that allows LabVIEW to transmit and receive data between computers and other applications. One of its many uses involves reading html source code from web servers.
I've attached an example. Pretty easy, isn't it?
Jarrod S.
(4,327 Views)
Hmm...
I used this method since Labview 6.0, but I remember it  doesn't work with URL ends with ".html"Smiley Tongue
Try to open URL http://www.x-rates.com/d/KRW/EUR/data120.html for example and you'll see ERROR 1184
But if you try http://www.x-rates.com  everything works fine. Can you guess why?
Of course Activex method is little more complex but works everytime.
(4,116 Views)
