how to make 'english' labview exe comfiled file or "espanol" labview exe comfiled file?
<Questions>
1. I want to create LabView that displays in Spanish.
2. Is it possible to implement it in the Korean version of Windows 11 Pro purchased in Korea? What language should I purchase Windows in?
3. What language version of LabVIEW should I download? 32bit standard (English, French, German, Japanese, Korean, Chinese)
<Questions>
1. I want to create a LabView program that displays in English.
Message 1 of 8
(2,888 Views)
Hello.
I am using Korean labview.
I would like to know how to put spanish language at the front page (which user sees).
When I need to use chinese language, I usually install chinese labview and write chinese language for the user page(out side of the vi)
or I think language brake up into awared picture.
I notices, there are only 6 language labview available for 32 bit, and 64bit for english language.
english
french
german
japanese
korean
chinese
Is anyone useing spanish for comfiled user page?
Thank you!
Message 2 of 8
(3,080 Views)
<질문사항>
1. 멕시코 납품용 스페인어로 표시되는 랩뷰를 만들고 싶습니다.
2. 한국에서 구매한 window 11 pro korea 버전에서, 구현가능한가요?
어떤 언어로 되어있는 윈도우를 구매해야하나요?
3. 랩뷰는 어떤 언어 버전을 다운받아야 하나요? 32bit기준 (영어.프랑스어.독일어.일본어.한국어.중국어)
<질문사항>
1. 영어로 표시되는 랩뷰프로그램을 만들고 싶습니다.
Message 3 of 8
(2,819 Views)
<Preguntas>
1. Quiero crear LabView que se muestre en español.
2. ¿Es posible implementarlo en la versión coreana de Windows 11 Pro comprada en Corea? ¿En qué idioma debo comprar Windows?
3. ¿Qué versión de idioma de LabVIEW debo descargar? Estándar de 32 bits (inglés, francés, alemán, japonés, coreano, chino)
<Preguntas>
1. Quiero crear un programa LabView que se muestre en inglés.
gracias
Message 4 of 8
(2,870 Views)
Accepted by topic author wentingeeeeee
Here are some good articles to read,
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3QKCAY&l=en-US
https://www.ni.com/docs/en-US/bundle/labview/page/localizing-vis.html
Note: Typically, you buy software where you select the language to install, which is typically enforced by the language of the OS, and you need not buy separate versions of software for each language.
Santhosh
Soliton Technologies
Message 5 of 8
(2,881 Views)
Please do not create multiple posts for the same topic - https://forums.ni.com/t5/LabVIEW/Qu%C3%A9-debo-hacer-con-mi-entorno-inform%C3%A1tico-al-desarrollar-...
Santhosh
Message 6 of 8
(2,878 Views)
I am sorry to make same questions in different languages. I have read the guideline. I will be aware of it next time.
Unofficial Forum Rules and Guidelines - Discussion Forums - National Instruments (ni.com)
(Sorry. I can't fine the 'erase button'. So i will let the question stay as the same position.)
Thank you so much.
Message 7 of 8
(2,824 Views)
@wentingeeeeee wrote:
<Questions>
1. I would like to create a LabView display in Spanish for delivery to Mexico.
<Questions>
See Localizing Your LabVIEW Application to Different Languages and How to Publish a LabVIEW VI or Application in Multiple Languages
https://tmesystems.net/
Message 8 of 8
(2,788 Views)
