how to keep "System Exec" section open
I use "System Exec" to launch a Python script.  The script launched successfully, however, the System Exec also ended.  There are many environment settings done by this Python script so I want to keep the section open for subsequence Python scripts/commands.  Could this be done with "System Exec"?  If not, what is the easy way to do this.  Some example would be great.
thanks,
-a
(3,128 Views)
Hi Anh,
it should stay opened if you connect a false constant to the "wait for end of operation" input on top of the vi.
Another possibility could be to load your script from a batch file with a "pause" command at the end.
Mike
Message Edited by MikeS81 on 01-23-2009 09:23 AM
(3,126 Views)
(3,122 Views)
Hi Mike,
I tried that "wait until completion -> False" already.  It will keep the actual "cmd window" open, but not the Labview section.  What I want to do is to run the initial Python setup script, keep this Python section open, then at random times later, my LV program will send more Python commands/scripts to the same opened-section.
thanks,
-a
(3,120 Views)
Have you tried LabPython?
Jim
(3,100 Views)
