how to integrate ni-labview with windaq pro+ software
Hello sir,
Im working with windaq pro+ software with DI-720 kit, my question is that is there any possibility to interface that software eith Ni-labview?
(3,143 Views)
swathi.1356016@srec.ac.in wrote:
Hello sir,
You should do a "LabVIEW Windaq" google search, it shows that Windaq has ActiveX controls (and even LabVIEW drivers) which once installed would show up as drag/drop VI on your LabVIEW pallette.
-BTC
New Controls & Indicators made using vector graphics & animations? Click below for Pebbles UI
(3,128 Views)
(3,123 Views)
thanks for the reply. it is useful for mywork. I have tried out the example in labview, in that could you explain me why the value of channel selected has been decremented by 1?
(2,955 Views)
I have used activeX control to interface labview with windaq software and also recorded the data(voltage in an current transformer), but the problem is that error percentge which i obtained varies for successive measurements. Is  there any way to rectify this problem.
(2,897 Views)
