how to install NI-DAQmx ver 2.0.1 into PDA?
hi there
I could not find this program C:\Program Files\National Instruments\NI-DAQmx Base\Pocket PC\daqmxb.sa.CAB in my laptop. is there another way?
Message 11 of 15
(1,224 Views)
ok i have found it and tried to install manually but there is still the error message appear.
Here is the error message:
The file "\Windows\nirlpdrvs.dll' is in use or is in ROM. If the file is not in ROM, please close the application using the file.
How to solve this error?
Message 12 of 15
(1,210 Views)
Hi, student G.
Is that the exact same message you were receiving before? (And if so, does it appear under the same conditions?)
Thanks!
Sarah K.
Search PME
Message 13 of 15
(1,195 Views)
yes it is the same error as before
Message 14 of 15
(1,190 Views)
Hey G,
It looks like you are running into problems with the manual installation. Have you tried the automatic installation? All you need to do is have your PDA connected with ActiveSynch running and then run the DAQmxBaseCEsetup.exe file located in C:\Program Files\National Instruments\NI-DAQmx Base\Pocket PC.
Hal L.
Message 15 of 15
(1,164 Views)
