04-17-2009 08:03 AM
i am a new labview user. how can i insert desired values in a 1D array or how can i simply give a desired bit stream exp. 110000110110 etc as an input in the form of a 1D array to some thing. i want to give a certain bitstream as input to a convolutional encoder. it accepts input in the form of a 1D array.
thanks
04-17-2009 08:36 AM
Hmm have you inspected the functions in the array palette ;). A tip since you are new in Labview. Then you start a new Labview session, always enable the context help (short cut Ctrl+h). If you want to modify several values in an array you have to use a for loop and shift registers.
Hope this was of some help
04-17-2009 09:15 AM
irish_sunset wrote:it accepts input in the form of a 1D array.
A 1D array of what? That will pretty much answer what kind of array you need to make.
04-17-2009 10:04 AM
i just want to input 100010001100001 etc. to a convolutional encoder. now the convolutional encoder takes input in the form of a 1D array. how do i input these bits in an array controller on the front panel.
04-17-2009 10:06 AM
By the way, the images you posted don't show up because the links point to a location on your hard drive which we don't have access to.
Please attach the image files to your message, then post. Then you can go back and edit the message to insert the images based on their NI webserver location.
04-17-2009 10:35 AM
04-17-2009 11:25 AM
04-17-2009 12:48 PM
04-17-2009 12:54 PM
04-17-2009 12:59 PM
PLEASE do not post bitmaps by changing the filename extension to .jpg/.gif/whatever. Doing so does not change the file format!
Sorry, but this is a real pet peeve around here.
That wire is just an array of integers. The subVI expects an array of I8. Based on your picture it seems your question has more to do with the front panel indicator. To view more values, just resize the array indicator.
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
