In my application the table is kept inside the event structure.I select the cells in the table (using mouse) on running time.How to get the selected number of rows & columns in that table?
You can fill selected values of the table by writing to it or the corresponding property using a property node - the table is just a 2D array of strings. I think for your "disable" question you are referring to the shortcut menu (when you right click). If you are using LabVIEW 8.x, you can edit or disable that shortcut menu - just right click on your table at edit time and choose Advanced >> Run-Time Shortcut Menu.
