02-17-2012 12:15 PM
Hello
I am a beginner of LabView. Now I do a project in school with cRIO 9074.
My problem is that I have deleted the embedded controller system by fault. But in the Measurement and Automation software I didn't find the controller sysyem which have the fonction of monitor on line. How can I download the load file?
Wait for your help, and thank you for your help very much.
02-20-2012 03:36 AM
Even if you format the cRIO system it should be found by the MAX and by opening the Software config you can reinstall the system files assuming that they are installed on the connecting system (PC).
So you have to use the MAX to setup the cRIO. Maybe it is of help to set the DIP switches to NoApp and IPReset first.
Hope it helps
Christian
03-06-2012 04:13 PM
Thank you very much for your help.
Now the problem have been solved. Thanks again for your help.
Eric Douai
