how to get the number of bytes at TCP port
Hi all,
How to get the number of bytes to read at the TCp port...as someone had suggested in some forum we do read the number of bytes first and then pass this...
but we get a problem when we have FF data in this...because then it sends 2 FF data...and cause of this we skip the last data...is there any solution for the same?
(3,616 Views)
Hi
In LabVIEW you don't have the same property as in serail port.
You havn't "Byte at TCPIP port".
if you developp a protocol, one soltion, is to send the size to read.
Ingénieur d'Application / Développeur LabVIEW Certifié (CLD)
Application Engineer / LabVIEW Certified Developer (CLD)
(3,595 Views)
Podría ser mas claro,  ¿por que "TCP read" usa en la entrada de "bytes to read" valor 4?
(2,946 Views)
Hi Aldo,
Because the string length is encoded as I32 value in 4 bytes…
(2,932 Views)
