Showing results forĀ
Search instead forĀ
Did you mean:Ā
how to get multiple columns from a 2d array in a loop
I wanted to select several columns from a 2D array and form a new array which will be my final data.
I have the program below. I would like to know if there is a smart way to do it using FOR loop.
I've tried once but no success.
(5,069 Views)
Maybe I'm reading this wrong.
Aren't you just deleting certain columns out of your 2-D array?
The Delete From Array function may be what you're looking for.
You could even call it in a loop if you use high to low sorted array of indices to delete.
(5,062 Views)
Taki,
Delete would also work. But I cannot figure out the correct way to do it. The array was not sorted.
(5,059 Views)
Accepted by topic author Coben
Autoindexing is your friend.
Pretty sure this should work.
(5,056 Views)
