how to get decoration's image
Highlighted
i can get the position ,bounds of decoration use property node , but how to get the image of decoration
(174 Views)
Highlighted
Accepted by topic author 8259
Take a screen shot of it.
What are you planning on doing with this image?
If you need to get the image by LabVIEW code, you can create an invoke node called Get Image of the front panel.  Use the position bounds to extract the part of the image array pertaining to the decoration out of the full array.
(165 Views)
i want to get the image by labview code , and save it as pictrue file. is there a invode node can get image like button control ?
(95 Views)
Highlighted
hope it have a simple way to get the image
(94 Views)
Highlighted
Hi 8259,
see message #2
(It's simple and in pure LabVIEW!)
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
(89 Views)
