01-19-2013 09:57 PM
hello guys, I need some help, I am new in LV, I have done some simples programs using serial ports so far. but now I need to use ethernet port to get data from a data scanner, I must process that info an then I need to print out that information, using only ethernet port, I ve never used ethernet devices in labview, so If some body can give a some help How to do that, I will appreciate thanks
01-20-2013 08:11 PM
01-20-2013 09:03 PM
thanks for your response
is there any function I can use for ethernet communication? because someone told me that I need the OPC module to work with ethernet
thanks
01-20-2013 09:26 PM
01-21-2013 05:03 PM
I have several serial scanners but I need to use ethernet , so I am converting serial to ethernet,
I will scan 2D barcode labels and need to process that info in labview and then communicate with slc5/05 and also
need print some labels in a zebra printer
I ve never worked with ethernet communication in labview, so if someone have any idea
I appreciate your help
thanks
01-21-2013 05:11 PM
Check-out the TCP/IP examples that ship with LV.
Mike...
