06-29-2011 12:53 PM
Solved! Go to Solution.
06-29-2011 12:58 PM
One workaround is to drop your while loop inside of a case structure and perform your comparison before dropping into the while loop.
Another possibility may be to use a Conditional for loop where you have the possibility of wiring in zero to the iteration terminal based on a comparison.
