how to get a time averaged data from DAQ 6009
in between the dynamic data to array function andaditions what is the function you have used. I 'am not understanding that thing. And other thing is that what will be the sample rate and number of samples I have to give so that I will get a 100ms averaged data. Please kindly reply to these queries
Message 11 of 17
(964 Views)
Hi perumpadapu,
I'm still attaching snippets, so why don't you look into? It's "From DDT", set to "2D array, signals by row"...
For sample rate and block size: let's think about it!
You sample with a rate of 1kHz and you need blocks of 100ms. How many samples will that be? Let's calc: 1kHz*100ms=1000*0,1*Hz*s=???
Message 12 of 17
(962 Views)
in your snippet you had used index array function or insert array function or someother please make it clear to me. KIndly help me.
Message 13 of 17
(958 Views)
can you please sent a working program of your snippet. And when I connect the array to subarray output to the mean its not wiring properly a broken wire with message you have connected terminals of different types. Please reply
Message 14 of 17
(958 Views)
Hi perumpadapu,
it's an IndexArray.
Why don't you attach your current VI? You have those problems and it's your part to show what's wrong...
Which LabVIEW version do you use? Why don't you use those snippets?
Message 15 of 17
(956 Views)
I'am attaching the program
Message 16 of 17
(951 Views)
Hi perumpadapu,
do you spot the difference?
It's still a snippet (according to linked context help given before)...
Message 17 of 17
(948 Views)
