how to get a rid of unnecessary numbers.
hello every one,
i have one number which is 0.125401 i just need to show 0.12 and get a rid of other (5401). how can i do it?
thank you in advance.
(1,112 Views)
Hi new,
the easiest would be to change the formatting options used for your indicator.
On the other hand you want to explicitely ROUND DOWN in contrast to default "bankers rounding" when you want to display "0.12" for a given input of "0.125401" - most would expect a display of "0.13" instead.
So the answer is: multiply by 100, round down, divide by 100, display using a format of %.2f…
(1,094 Views)
Getting rid of numbers is very difficult.
Here is a little number that just keeps showing up! Totally unnecessarily
"Should be" isn't "Is" -Jay
(1,073 Views)
🙄 Uhg!  Is NO PLACE sacred anymore?  What a world. 😩
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019 - Unfortunately now moving back to C#, .NET, Python due to forced change to subscription model by NI. 8^{
(1,031 Views)
@newmemeber123 wrote:
hello every one,
Completely ambiguous questions:
What is the datatype of the "number"?
  • If it is a string just take the substring from the beginning to 2 characters after the decimal points.
  • If this is a numeric indicators, just change the display format to show two decimal digits (right-click...display format. And yes, that would show 0.13 in your case).
  • If this is a floating point datatype (DBL, SGL) and you want to truncate the actual "wire data" for a fixed number of decimal places, you are out of luck because most fractions that look nice in decimal would need an infinite number of mantissa bits in the internal binary representation. Impossible!
(998 Views)
This is one way you can do it, there are many others.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(983 Views)
