how to get PC host name using labview
hi,
I have a need to display the pc host name(login name) in my application. How can i get it using labview in runtime i.e. if i write a program and execute it in different PC systems/same system with different users, then i should get the corresponding login names.
Can any one help me on this?
Arvinth
Message 1 of 8
(5,958 Views)
Accepted by Mr.7
Should be available in LV RTE
Message 2 of 8
(5,955 Views)
Well, the PC host name and the login name are two different things, so which one are you trying to get? Darin's snippet gives you the login name. If you want the PC name use this method.
Message 3 of 8
(5,947 Views)
Thankyou for the answers..I want to display the login name..i have labview developer suite..i am not to get the option in real time menu in the functions pallette.
do i need to install any tool kit?
Message 4 of 8
(5,924 Views)
Now you are asking about real-time instead of run-time. There is a big difference. What exactly do you want?
Message 5 of 8
(5,911 Views)
Ok i wanted to display the login name of the computer in runtime.
Message 6 of 8
(5,903 Views)
Then the answer you got will work just fine.
Message 7 of 8
(5,901 Views)
Thankyou Darin..
Message 8 of 8
(5,886 Views)
