취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
how to get PC host name using labview
해결 완료!
솔루션으로 이동
hi,
I have a need to display the pc host name(login name) in my application. How can i get it using labview in runtime i.e. if i write a program and execute it in different PC systems/same system with different users, then i should get the corresponding login names.
Can any one help me on this?
Arvinth
0 포인트
1/8 메시지
7,741 조회수
솔루션
주제 작성자 Mr.7이(가) 승인함
Should be available in LV RTE
2/8 메시지
7,738 조회수
Well, the PC host name and the login name are two different things, so which one are you trying to get? Darin's snippet gives you the login name. If you want the PC name use this method.
3/8 메시지
7,730 조회수
Thankyou for the answers..I want to display the login name..i have labview developer suite..i am not to get the option in real time menu in the functions pallette.
do i need to install any tool kit?
0 포인트
4/8 메시지
7,707 조회수
Now you are asking about real-time instead of run-time. There is a big difference. What exactly do you want?
0 포인트
5/8 메시지
7,694 조회수
Ok i wanted to display the login name of the computer in runtime.
0 포인트
6/8 메시지
7,686 조회수
Then the answer you got will work just fine.
0 포인트
7/8 메시지
7,684 조회수
Thankyou Darin..
0 포인트
8/8 메시지
7,669 조회수
