how to generate day of week from date
Does anyone know how to generate the day of week (monday, tuesday) for a given date (i.e. Jan 01 1996)?
Unfortunately, the LabView 6's 'Date/Time to Seconds' VI requires day of week info.
(8,442 Views)
Actualy you don't realy need this value. Just use 0 for day of week. LV will automatically calculate this. See attached example.
Michael Aivaliotis
VI Shots LLC
(8,442 Views)
Here is one way of getting the name of a given date. Hope this helps. /Mikael
(8,442 Views)
additional possibility - I use it as sub.vi
regards
wha
(8,442 Views)
Probably already been answered, but extended help for this function
indicates that day of week and day of year are ignored.
"eyebe" wrote in message
news:50650000000800000002310000-1004225886000@exchange.ni.com...
> of week info.
(8,442 Views)
eyebe,
If you just want to know the current day of the week, use the LabVIEW "Get Date/Time String" function and use Long format, then parse out the day of the week. Or, an easier way would be to use the "Get Date/Time in Seconds" wired into the "Format Date/Time String" with "%A wired to the format string.
If you want either for a specific time, you will have to translate the date/time you want to seconds since 1/1/1904 and input it into either function above.
Good luck
(8,442 Views)
