06-22-2020 08:36 PM
Hi
I've run into some problems about how to generate continuous wave generation using PXI-5412.
Here is my program code.
When I don't add delay in the program, the waveform I send is different from the set one and it's messy. Only when I add delay can I have a stable and correct waveform. I don't want delays to affect the real-time nature of the program. So I want to know how to generate a continuous and stable waveform without delay.
Thank you.
Solved! Go to Solution.
06-22-2020 10:08 PM
It will be difficult for many of us to help you. First, your program is in LabVIEW 2020, which only some of us have installed. Second, you use a specialized Toolkit that I don't have installed (and don't even know which one it is), so when I open your VI, I see a dozen "unknown functions" that I cannot comment about.
Can you save your VI for an earlier Version, and also tell us what Modules and Toolkits you are using? That would help bring your question to the Experts with appropriate experience.
06-23-2020 03:03 AM
I am sorry, and I will save the program as previous version.
Thank you for your advice and help,sir
06-23-2020 03:36 AM
I am using NI-FGEN and NI-SCOPE moudles,and I have saved my VI as 2015 Version.
Thank you.
06-23-2020 09:34 AM
NI-FGEN and NI-SCOPE are drivers for specific devices and modules (function generators, arbitrary function generators, and arbitrary waveform generators, and acquisition hardware that "exercise the functionality of the oscilloscope". I'm not sure if the general-purpose LabVIEW Forum is the best place to find people using these devices, but I'm not sufficiently knowledgable about these devices to suggest a more appropriate NI Forum.
You might try going to forums.ni.com, looking at the Discussion Forums, and see if you can find one discussing Drivers, or Hardware that seems to include these products.
