how to generate PWM signal by using digital lines of NI PCI 6224
I am doing a project on Speed control of DC Motor. I want to use Labview to control the speed of dc motor. I am using NI PCI 6224 M card. It does not have ANALOG OUTPUT. It has just DIGITAL OUTPUTS.
I want to generate a PWM signal from labview by using digital output lines. This PWM signal will trigger the base of MOSFET/transistor. My issue is just that HOW I CAN USE DIGITAL LINES TO GENERATE PWM SIGNALS ???
Ayaz
(2,383 Views)
Duplicate post.
Regards
JamesC
NIUK and Ireland
(2,363 Views)
