01-03-2014 11:29 PM
Hi i am john,
I need to find the ratio of 1st and 2nd frequencies in fft graph.
Already i got information from this site only. Mr. Alten helped me.
Now i have to continue the same problem and need to find the ratio of the frequencies.
Please someone help me guys....
I will attach my vi file and text file.
Solved! Go to Solution.
01-04-2014 11:05 AM
john,
Do you need the ratio of the frequencies or the ratio of the amplitudes of the components at those frequencies?
The Extract Multiple Tone Information.vi from the Signal Processing >> Waveform Measurements palette should do what you want.
The frequency resolution is not very good because you have relatively few cycles of the waveforms (~2 for the lower frequency). I added some zero padding to improve the resolution, although a larger data sample would be better.
Lynn
01-05-2014 10:11 PM
Thanks a lot Mr.JohnSold.
But i need to find fft for the other sample of datas. i cant be able to get it through the vi which u have posted. please check it and send me the new program. Sorry for disturbing u.
PFA
01-05-2014 10:58 PM - edited 01-05-2014 11:00 PM
Why can't you use the same VI on a different set of data?
Why did you post the exact same response to your other, very similar message trhead about FFT.?
http://forums.ni.com/t5/LabVIEW/How-to-get-fft-for-my-xy-graph/m-p/2685637#U2685637
Don't create a new thread for the same question. Keep your responses in the other thread.
(PS. There is no word spelled "u". There is, however, a word that is spelled "you".)
01-06-2014 02:37 AM
sorry. But i need it urgent. Please do the needfull
01-06-2014 01:22 PM
The negative times in the two files you posted may be part of the problem. Shift the time axis so that all the data occurs at non-negative times and see if that helps.
Lynn
01-06-2014 10:57 PM
Its not coming properly. Will you be able to help with the program
01-06-2014 11:57 PM
Look at my reply in the other parallel thread.
The negative times are not a problem, because we only care about dx in the resampled data. You simply need to ensure to trim the leading zeroes due to the non-numeric file header. (or edit it out manually from the file).
(Also please don't use these doule-extension. *.lvm.txt. That only confuses!)
