how to extract till the first value after the decimal in a dbl
Hi Guys
I want to take a number upto its first significant  value after the decimal point.
For example. If I got a number as 11.1234. But I want this number as 11.1.
How can I convert this number in labVIEW?
(3,842 Views)
Hi trip,
did you try a format string of "%.1f"?
Or you may round after reading in your number: y := RoundToNearest(x*10)/10…
(3,831 Views)
Multiple Possible Methods
Method 1.As suggested by Gerd (Format into string) and then Converting the string value to Numeric Value
Method 2.Convert Number to fractional String with precision1 and then convert back Fractional string  to Number
(3,812 Views)
Method 3: multiply number by 10, convert to integer, then divide by 10. (This truncates unwanted precision)
Method 4: same as Method 3, but use Round to Nearest in the middle. (Gives a rounded result)
Can you say a bit more about the whole problem? Do you have just a single number that you want to convert or is this value part of a data stream, list or array, where you have some number of sequential values you need to process?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,794 Views)
