11-28-2006 08:07 AM
11-28-2006 08:14 AM
11-28-2006 08:27 AM
hey Jorge...
i appreciate the quick response. the version of labview that i have is 8.0. im sure it should be compatible.
what you suggested is actually a good idea. but im trying to build a front panel that allows a user to corrupt (add noise) to either the R, G or B channel and also have an option of what kind of noise will be used (gaussian, poisson, random) etc.
thanks again!
dee.
11-28-2006 08:57 AM
11-28-2006 09:05 AM
11-28-2006 09:44 AM
11-29-2006 06:57 PM - edited 11-29-2006 06:57 PM
Hi dee,
You have the right idea. However, you should use a different image data 2D array for your input to the Colors to RGB VI. Take a look at the attached VI (it's version 8.0). Reading the Help files for those VIs will make things clearer.
Hope that helps!
Message Edited by Kalin T on 11-29-2006 06:58 PM
11-29-2006 09:49 PM
