how to export xy graph with indicator field.
hi,
 I want export my graph in .emf format.For this i have used invoke node>>Image export. If i use this , i can only export the graph not other indicator filed(numeric and string indicatror).how can i export graph with indicator field??
here is .vi that i have used.
(2,237 Views)
Accepted by topic author tadhika
Thanks for your post in our Discussion Forum,
is it necessary to export the picture in the .emf Format?
Otherwise I can provide two possibilities:
The easiest way to make a screenshot of a certain area of the frontpanel is to
create a SubVI with all the elements you want to take a screenshot from and
then take a screenshot from the whole frontpanel of the SubVI.
This works fine although the frontpanel is not visible while the picture is taken.
The screenshot can be taken with a method-node as seen in the example attached to this post.
Another possibility is to crop a screenshot of a whole frontpanel to the region which you are interested in.
How this works is described here: http://forums.ni.com/t5/LabVIEW/take-screenshot-of-part-of-front-panel/td-p/1613750
The downside is that you have to manually set the region which might change due to scrolling or changes on the panel.
Peter
(2,196 Views)
thanks .I did as u said.and it works well.now its fine..thanks.
(2,193 Views)
