how to execute multiple event from an event structure at once?
So I have an event structure with multiple events that have buttons on the front panel and I want to be able to switch multiple buttons at the same time with one button (execute multiple events with one event or action). How do I go about this?
Message 1 of 10
(4,522 Views)
State machine, or rather a Queued Message Handler.  Have each button go to a state.  Then you can have one button that goes to each of those states one at a time in the order you want.  I'd recommend the JKI State Machine.
Message 2 of 10
(4,511 Views)
You can have one button that sends a value to multiple Value (Signalling) properties for the other buttons.
But you can never have multiple event cases in a structure execute at once.  It can queue up multiple events, but an event won't execute until the previous event is done executing.
Message 3 of 10
(4,496 Views)
would you be able to point me to any examples?
Message 4 of 10
(4,495 Views)
From the description. You need  1 to many synchronization method.
That means Notifier.  Gather all the data elements you need and fire the notifier (not sure about a channel option).  You will need a parallel loop for each notifier consumer and they could act on separate elements of the notifier data.  Each parallel loop will see the notification at the same time and do its job while the other things do their business.
OS and hardware limited of course.  For instance you can only send one message at a time on the same GPIB bus and there are a finite number of hyperthreaded cores in the CPU.
There is a notifier shipping example showing this
"Should be" isn't "Is" -Jay
Message 5 of 10
(4,472 Views)
@JÞB wrote:
@mshask
That's called a Tag Channel.  It's a Notifier on Steroids.
Message 6 of 10
(4,460 Views)
where is this example located?
Message 7 of 10
(4,453 Views)
To find examples in LabVIEW:
  • Start LabVIEW.
  • Under "Help", click Find Examples.
  • Do a Search, for example, "Notifiers".
  • Click on an "interesting topic".
In LabVIEW 2018, doing this will bring up several examples.  One "Wait on Multiple Notifiers" example suggests that you can stop routines using the Notifier by releasing it, thereby causing Errors on any routines using it.  What?  Sloppy, a mis-use of the Error Line!
But there's also the final entry brought up by the Example search, for Channel Basics.lvproj.  Example 3 shows the Tag Channel in action as a Super Notifier, with its ability to (if you choose to do so) send a "This is the Last Notification" notice to all listeners, who can decide to exit if that's appropriate.  Civilized -- telling your colleagues that you are done with their services, rather than simply shooting them all ...
Message 8 of 10
(4,440 Views)
Here is the JKI State Machine:
https://www.ni.com/en/support/downloads/tools-network/download.jki-state-machine-for-labview.html
And here is a video showing some of its basic functionality.
https://www.youtube.com/watch?v=XJFujhIuZdU
The other suggestions given are also useful and can probably do what you want, but personally I'd do it with a QMH.
Message 9 of 10
(4,435 Views)
Not sure exacty...  I'd just open any LabVIEW window.  Go to the Menu》Help》Example finder.  Sip coffee... keyword search "Notifier" and read the discription text in the top left pane til it sounded about right.  Maybe I'd even open something else and learn the wrong things by accident.
I let NI R&D worry about where they put it.
Message 10 of 10
(4,434 Views)
