09-28-2010 07:53 AM
09-28-2010 09:15 AM
Do you have a string indicator or a numeric indicator? If it's a string indicator do you have it set to hex display mode or normal display mode? What you posted implies it's on hex display mode. If it's on hex display mode have you tried switching to normal display mode? What does the documentation for the device say that you're supposed to get? Does it say you're going to get a bunch of hex values or does it say you're going to get some human-readable characters? We don't have the device or the documentation.
09-29-2010 01:09 AM
i have string indicator and have it been set to HEX display. if i change it to normal display it will show unidentified value.
so the problem is i dont know what NGM has send to labview. attached is NGM manual,u can try to understand it and encode the HEX value that i get
09-29-2010 03:52 AM
According to the attached manual it looks like you queried a whole page of registers. So each register value is tab delimited and the order of registers is defined by the page you queried.
You have to convert the 16bit register values from Hex to Int16 ( i.e 0100h = 256 ) using the HexadecimalStringToNumber VI.
Hope it helps
Christian
09-29-2010 06:00 AM
09-29-2010 06:10 AM
09-29-2010 06:19 AM
09-29-2010 06:21 AM
Next transmission due in 7 minutes
09-29-2010 06:42 AM
09-29-2010 07:48 AM
How do you get this data? Does it send it continuously, do you send an enquiry? Tell us more about how you get this data.
